Cooler Master has a really interesting new HTPC/Meia Server case out. Tons of space inside and 120mm fans standard. For those of us who want full gaming, workstation and/or server functionality out of one box, this might just be a great option. This info is from 3DGameMan.com :
Cooler Master CM Media 280 HTPC Case
Overview:
The wait for a Power HTPC is finally over, introducing the new CM Media 280/281, with its roomy interior capable of supporting NVIDIA SLI / ATI Crossfire Configuration and capacity to hold up to five HDDs. It is also compatible with RAID configuration. The spacious dimensions allow you to have full-length cards, including the NVIDIA G80 SLI. With its hair-line high-quality aluminum appearance, it will be the highlight of your Power HTPC.
Features:
- Unique mechanical design (Pedestal / Desktop convertible)
- Spacious Dimensions to support NVIDIA SLI / ATI Crossfire Configution
- Elegant and Sturdy Aluminum finishing front panel design to blend in seamlessly into your working or living space
- Vacuum Fluorescent Display (VFD) and Hot Keys facilitate the use of Microsoft Media Center Edition (Optional for CM Media 281)
- Eight air ventilation areas for optimal airflow and cooling while providing silent solution
- Get ready for Microsoft Window Vista
Specs:
Available Color: Black
Dimensions: (W)430mmx(H)178mmx(D)477mm
Material: Chassis: SECC, Bezel: AL+ABS
Motherboards: ATX, Micro-ATX
5.25" Drive Bay: 3 (Exposed)
3.5" Drive Bay: 5 (Hidden) , 1 (Exposed)
Cooling System: One 120x120x25 mm Rear Silent Fan(1200 rpm, 17dBA), One 120x120x25 mm Front Fan (Optional), One 120x120x25 mm Top Fan(Optional), One 120x120x25 mm Side Fan(Optional)
Front I/O Panel: USB 2.0x2, IEEE 1394 x1, MIC x1, SPK x1
Expansion Slots: 7
VFD Display Remote Control: Included
Weight: 9.3 kg
Multimedia Hot Key: Included
Power Supply: Standard ATX PS2/ EPS 12V (Optional)
____________________________________________________________ __
Link to product page:
Cooler Master CM Media 280 (RC-280)
Link to an early European review I found:
www.presence-pc.com Review (translated from French by Google)
One of the best bits of news I've found about this case is that the suggested retail price may be under $220.00 for the RC-280 version of the case that includes the remote and VFD, and around $120.00 for the RC-281 version without. Looking forward to seeing this one hit American shores!
I've attatched a couple of images below. Any further information on this case and/or its current/future availability would be highly appreciated.
Overview:
Features:
Specs:
Expansion Slots: 7
Weight: 9.3 kg
