I'm looking at putting together a non-obtrusive HTPC so I have some requirements:
The internals will most likely consist of:
Based on this, there were 2 cases that I found that worked for me. The first one was the HIPER Media Chassis. It had the slim design which I really liked and supported mATX, but I don't think it comes with a remote and it's impossible to find in the US. It's also a bit underpowered with a PSU rating of 220 at peak load. It might be enough for the limited amount of components I have in it, but it might not be. I would rather have more than enough and be able to add on some components later if need be.
That led me to the Cooler Master RC-260. It's a a bit larger than the HIPER Media Chassis, but it comes with a remote and can support most standard size ATX power-supplies. It'll also support a full ATX board if need be (but I don't think so).
It's been a very long time since I put together my own computer since I went mostly laptop in my house. There are some restrictions on the type of board that can be used in the RC-260 with the PCI-E x 16 Riser, so question number 1 is: Will the ABIT board fit?
Then there is always the question about the case itself and the quality of it. Has anyone else used it and have they had any problems? I've read some reviews and they seem to be fairly good, but I'd like to hear real-life examples.
And finally, is my setup going to be ok? I'm in the mindset that a HTPC should be a thin client to a beefier, but hidden, server to store and serve up the content to the remote clients so I think I should be good.
As always, thanks for any info you can provide.
- Must be no more than 3.5" tall
- Must look like a normal piece of AV equipment
- Must have a remote control/IR package
- Support an ATX or mATX board
- Universal ABIT NF-M2 nView MB (don't need a separate video card or sound card with this since it's got the DVI and Optical SPDIF onboard plus a 10/100/1000GB ethernet)
- AMD Athlon 64 3800+ Orleans 2.4GHz Socket AM2 Processor
- 1 GB of RAM (CORSAIR XMS2 1GB (2 x 512MB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400))
- DVD +/-RW
- 120GB HD (media content will be either on the network or an external drive so a large drive isn't needed, just big enough to run Linux)
