Originally Posted by MichaelJHuman /forum/post/12981892
I always thought pulling hot air out of boxes was the preferred direction. Anyway, increasing the air pressure inside a case should push air out through the vents. Seems it should would that way, anyway.
You could always buy one of those nifty (but pricey?) laser (infrared?) thermometers to check things out.
Pulling the air out is a preferred way, however, that is only if the air is pulled from/through where you need it to be pulled from. In some cabinet situations, the air can be pulled around equipment instead of through it which may not cool as well. In these situations, a fan blowing on equipment can be better directed to components.
I have my cabinet setup with an intake fan on the bottom left and an exhaust fan on the top right. In between, there is a shelf which has 3" of clearance between the front and the glass. This helps with pulling air across the receiver and taking out the warm ambient air, but that's not all I have done. I also cut a hole in the middle of the shelf and directed a fan upwards through the bottom intake vents of the receiver. It is amazing how cool my receiver stays now.
Before the cooling, I just opened the door when I used the receiver. This still allowed the heat to collect and I was uncomfortable with it. Another thing I did was plug the fan controller/PSU into the back of the receiver so it comes on when the receiver is turned on. I used Yate Loon 120mm fans @7v so I cannot even hear them.
On the other door of the cabinet, I have the same intake and exhaust setup for the Xbox 360. While this kept it much cooler than just opening a door, it was still warmer than I really liked given the reliability of these consoles. I made a duct from the Xbox fans to the cabinet exhaust fan which now keeps the console very cool with the door closed... Most of all, I got rid of the noise!
