Originally posted by Marcel J. Dumeny
"I would recommend that you try and keep the projector below 90F and using the supplied formula with an ambient temp no more than 80F, you should be fine with about 200CFM net flow."
Tom: Where are you measuring the projector temperature (i.e., the 90F)? Since the manual says that the ambient air temp should not exceed 95 degrees, I'm assuming that you measure at the air intake?
I believe the exhaust side air temperature runs anywhere from around 105 - 110 degrees, depending on ambient air and exhaust clearances. Is there a corresponding number as to how hot is too hot for the exhaust side? Since the projector has an internal temp cutoff switch, I assume that there is a sensor which checks the exhaust side temperature - what temp generates a shut off signal?
Marcel |
Marcel,
The D-ILA does have an internal temp cutoff - but I wouldn't size my cooling system based on that.
In another thread, Tom Stites states that "heat is the enemy for all things D-ILA".
If you have a marginal cooling system, you might not trip the temperature cutoff, and you might not
fail the projector right away - but why subject it to any more thermal stress than you have to?
It seems lots of people are trying to find the minimum cooling capacity that they can "get away
with". When it comes to cooling - that's just plain poor engineering practice.
I would accept Tom's recommendation of at least 200 cfm - and run with that. You can get cooling
fans with that capacity. Personally, I went with a "Radon fan" - fans that are used to exhaust
naturally occuring Radon, a radioactive gas; in areas that have trouble with that.
These fans are available from such companies as Infiltec, Fantech, and Deflecto; they are very
quiet, and come in sizes that can easily supply the 200 cfm cooling requirements of a D-ILA.
You can find them online - or at a "Home Depot".
Greg
