1 - 3 of 3 Posts
Hello All,
I too have a basement refurb underway and am wanting to mount a Sammy 58 Plasma in a corner. Is there a mount specifically made to mount large flat screens in corners?
Thanks in advance!
Bestpractice
Originally Posted by Bestpractice /forum/post/17051408
Hello All,
Thanks in advance!
Bestpractice
On my old 42" plasma I mounted it in the corner using a tilting swiveling type mount like this I just put the mount near the corner it was going to be in and pulled it out and sideways. The only issue I had was that after a while with all the weight on the side like that, the arm started to sag slightly. There is also obviously going to be a weight difference between a 58 and 42.
I did the same thing at a friends house. Used a swivel mount to kiddie corner the tv. Turned out pretty nice and could not see the mount.
The TV I mounted was only a 32" so not sure if this one would work for your tv.
Monoprice Swivel Mount
1 - 3 of 3 Posts
