I'm confused about proper Xover settinga for a full range speaker. For example, you have a pair of speakers that are rated at 22Khz- 35Hz. Do you set your preamp or sub to a Xover at about the low end range of your mains (in this case 35-40Hz) or should you go higher (50-50Hz)? It's seems to me if you go much higher than what the speakers will handle on the low freq range, it's almost a waste to get a full ranger speaker. Why not just use book shelf?
To be honest, I don't know what is considered a rule of thumb here. I know it's usually what sounds best to the listener but there has to be starting point.
Any help is appreciated!
Tony
Tony
