Hey there, new question on an old tuner for all ya'all...
Back in early June, we fixed up a Mitsubishi CRT Rear projection HDTV (all documented in Mr. Bob's "Don't Dump your CRT RPTV" thread, here on AVSForum) and finally noticed that we were being billed $5 per month for our mediocre Motorola Standard def tuner (who wants to watch digital standard def on an HDTV anyway?), so we went to eBay to look for something that could tune QAM cable (I have a Mygica USB QAM tuner that works great and pulls every channel you could imagine), and learned two things right away: 1, there are very few of these on eBay (mixed in with the crappy $40 standard def boxes) and 2, the ones that are there are very expensive. After shopping around in the low of the season for about a month, we finally settled on a Samsung SIR-T451 despite the bad reviews. We figured if it could tune QAM, we'd be good to go.
We finally got it today and it looks really nice. It must've been pretty incredible back in 2004. We plugged it up right away and did the channel scan with the sluggish (but still quite usable) menus. The channel scan finished quickly, and after a reboot, we finally got our bearings on "what was what". The first problem with this machine lies in the way it scans for channels. It checks the channel, and if there is any subchannels with content, it'll mark it as good, so for example, if channel 100-10 was the only subchannel in 100 with content, it would just mark "100" as "saved". When you go to use it, navigating to "100-10" requires that you first type "100" with the remote, then hit "channel up" through the empty channels 100-1, 100-2, etc. (you can't go directly to subchannels with the remote, you have to use "channel up").
All that I could easily live with, but the biggest problem is that the channels it finds do not line up at all with my solid Mygica tuner. The mygica found FOX in HD and I believe it found some of the other local channels (HD as well, if I remember correctly) as well as a bunch of other stuff (music channels and random other miscellaneous channels). The Samsung was "hit n miss" as it found most of the local networks in standard def, none of the music channels, hardly any HD channels (more on that in a second), and everything it did find was numbered completely differently than on the mygica. To save time, I eventually went through and made a list of all the channels that did come in so I knew where they were. In my cycle through, I later found 2, maybe 3 HD channels (which looked unusably "scrambled", the same effect as when you try to watch OTA channels and the signal is too weak) on a lower number (one of which was FOX), but not as many as before on the mygica.
Is this just because the tuner is too old? Is it only QAM64 and not QAM256? could anything else be causing me not to find quite all the channels?
- 2 Bunny
- 2 Bunny
