Could a broken HDMI cable cause lip sync issues?
1525 Views 13 Replies 4 Participants Last post by  DVD Freaky
I was an idiot trying to plug in my new Fire Stick streaming device into my JBL 2.1 Deep Bass Soundbar last night and tried to force the HDMI cable into a tight area for a couple of minutes, forgetting about the enclosed slim extender adapter you can use if you don’t have room for the main device connect.
I don’t know if I’ve broken a pin on the cable or damaged the port but at least one of the movies I sampled on Amazon Prime had clear lip sync issues. An article on “windowsreport.com” said a damaged HDMI cable can cause lip sync issues but I can’t find confirmation of that anywhere else online. Unfortunately, I can’t use another cable because this is a permanent part of the main Fire Stick device.
Does anyone know for sure that a broken cable pin or port damage would cause lip syncing? Surely there would be other noticeable video issues if there was damage?
1 - 14 of 14 Posts
No HDMI expert by any means, but I'd say no.
  • Like
Reactions: 2
Thanks…hope that is the case. We will see.
Nope if you get a signal the cable is doing it's job there's no limited signal scenario that I have ever seen
  • Like
Reactions: 2
Plug the Firestick directly to the TV.
Thanks…that’s what I’d figured but I’m no HDMI expert. I figured I’d see a degradation of the video before I started getting some lip sync issues. Guess I’ll chalk it up to settings or the title, though it’s not lip syncing via other playback devices outside my home theater. Could be the soundbar or some setting that’s causing some lag.
Lip sync would be purely software based I'd have to guess. My amp has a setting for it but I've never needed to use it because I've just never noticed it even if it is there
It’s a projector. If I run the Firestick directly to the projector, I wouldn’t get anything other than the PJ’s speakers for sound. Going via the soundbar seems the best route but I will need a switcher to add the PS4 as well, since the soundbar only has one input.
Yeah, I’m not sure. There’s only been one title so far on Amazon Prime that seems to have lip sync for me…and it’s not by a ton. It’s a little off though. If 99% of the titles don’t have lip sync, that’s good enough for me. I’ve only had my PJ and soundbar for a week, so all this is new to me.
Doesn't hurt to test though. If there's still a problem with sync, that eliminates the SB. ;)
  • Like
Reactions: 2
True. The HDMI cable seems to have survived my rough handling…not sure how much I set it back. Think I’ll have to get a switcher for my two sources into the soundbar so I don’t put any more pressure/wear on it or the port. I really used a lot of force on it and the port, foolishly. Just totally had forgotten about the extender.
Just keep in mind that HDMI ports are fragile in the sense that you don't want to keep unplugging/plugging your cables. The recommendation is to totally power off your system if you are going to unplug/replug the HDMI cable.
Lip sync issues are usually between the source/sink and not necessarily the cable.
  • Like
Reactions: 1
Thanks...I think I put the soundbar in "standby" mode when I unplugged/inserted HDMI cables, but should have unplugged the power completely first, as this soundbar doesn't have a true "on/off" switch. It just is either "on" or in "standby" mode.
If I do swap out the soundbar, I'm definitely going to get a switcher for it first, since it only has 1 HDMI input. Since the projector is 1080p, not 4K, I assume any switcher will do? Maybe a 4K capable one would be a good 'future proof' idea.
All you can do is try with the switcher. For HD (1080) you probably won't have any issues. Once you get to the higher video standards (4k, 4k HDR, HDMI 2.1 etc) you may encounter issues. Also, if you use active cables that will cause issues because active cables require a power source, which is usually the HDMI port.
  • Like
Reactions: 1
Thanks. Yeah, my HDMI cables are passive. I didn’t experience lip sync last night but I’m getting vastly varying audio and volume levels with the same content on different days, so I’m going to return the soundbar today. The picture quality suddenly vastly improved on my streaming content as well last night, out of the blue, and the audio was noticeably louder and fuller on almost every app. As far as I can tell from feedback on Avsforum, volume and audio quality should not buffer like video does, so I think there’s an issue with this soundbar. Sometimes a show is soft in volume and the next time, it’s louder. Returning the Fire Stick too. The varying levels happened on my PS4 apps too though, so it’s most likely the soundbar.
1 - 14 of 14 Posts
