1 - 6 of 6 Posts
I need a 20' run of RCA cable for the subwoofer but only have a 17' cable. Normally you would'nt want to couple a speaker wire due to loss but it's just a sub channel.
Does anyone see much of a problem with coupling another 5 feet of rca cable?
if you are talking about adding a second cable and using a "RCA female/female" coupler, then it will work fine. But by the time you buy a decent coupler and the extra cable, Mr. "Rijax's" suggestion makes much more sense, and you will end up with one coaxial cable making the 20' run with some to spare.
Discussion Starter · #4 ·
I had a time issue. I had 2 pieces here and im doing the install and conduit now. Didn't want have to stop the install and wait for shipping but it ready is the tidy and correct thing to do.
If its going to be in an inaccessible location you may want to provide some more support than the friction fit of normal RCA couplers.
Wrap it in electrical tape or something similar (not duct tape).
If you're located on in the west coast monoprice does overnight shipping for $4.73!
1 - 6 of 6 Posts
