1 - 2 of 2 Posts
Discussion Starter #1
getting all of my cables ordered for my theater build, and I have a question or 2.
1 - Why can you not use a composite cable for component? Looking at monoprice.com, they are currently out of the 25' component - but they have a 3-wire 25' composite... Both are RG59/U - isn't the color of the connector the only difference?
2 - how critical is the wire size for HDMI? It will be a 25' cable, 24 gauge is in stock, 22 gauge is not... My thinking is that 25' is not enough to really matter - what do you think?
Discussion Starter #2
I went ahead and ordered, so I'll see how it goes... any comments would be great though!
1 - 2 of 2 Posts
