1 - 1 of 1 Posts
TV is Samsung PN58c500, DVR1 is Magnavox 515, DVR2 Panasonic DMR EH75V
DVD player is Magnavox MDR3000.
I have started to manuelly setup the speakers w/ a Harmoy300 remote.
used the guide button as a setup function.
any suggestions on which buttoms to assign to the Harmony remote like HDMI (which toggles between TV and HDMI being used), HDMI 1,2,3 & 4. AV1, DVD player display, DVD player commercial skip ect.
I currently only have 2 front speakers Polk audio M30 w/ 5 1/4 woofer and a Polk audio 1200watt sub. woofer. w/ 8" woofer.
Here are my current settings w/out the use of the speaker mircophone.
1.bass out SWFR
2.center none
3.surround none
4.sub woofer phase normal
5.crossover set at 80
I have my sub. woofers crossover set at 80 also.
1.what is the recommended crossover for my speakers?
2.what is the recommended front speaker setting large or small I haven't notice much of a differnce between the two?
3.I have a (3.5mm wire) pluged into the back of my TV the other end of this wire has 2 RCA jacks plugged into the AV5 on the RX-V465
when I start listening to radio then start watching TV the audio stays on radio, I have to press the TV scence button to listen to TV is there a way around this?
I'm thinking the solution is an optical tosh link cable connected to AV1?
I would really like a volume punch though is this possiable w/ the Harmony 300?
4.I'm not liking the volume display the voulme starts at a -80.0dB I would prefer the start of volume to be set at 0dB and increase to 80dB is this possiable?
5.this RX-V465 gets kindof warm I have it mounted inside a wooden home entertainment box the back is completely open I am concerned this heat will ruin my 2 DVR recorders should I place a dividing piece of wood inbeween the RX-V465 and the 2DVRs?
6.I'm like still confused on what to use as a ground bar for the AM radio?
Thanks Guys
__________________
1 - 1 of 1 Posts
