Hi there fellows.
In order to improve my home theater, I recently purchased two Guitammer ButtKicker shakers as well as their respective Carvin DCM1000 driving amps.
I am planning to construct a raising wooden platform a couple of inches high (and along the guidelines recommended in the shaker's User Guide) to install my three(3) Berkline model 729 recliners on it. The two shakers will be symetrically placed on the rear of the platform, behind the recliners. The platform will be isolated from the carpeted floor by means of Mason Industries type "ND" neoprene mountings ( www.mason-ind.com/MasNeoMP.htm , www.mason-ind.com/masonanaheim/n/n102.htm , www.mason-ind.com/masonanaheim/n/n101.htm ).
Now, instead of four individual legs at their bottoms, each of the recliners have a circular base (28" in diameter) which provide the support surface for the recliner against the floor(or against the top of the raising platform
when it is ready). I am concerned that, because of the circular shape of the recliner's base, some "slippage" might occur between the recliner and the platform as the shakers vibrate the platform....particularly if one or two of the recliners remain unoccupied (ie. nobody seating on them) at a given moment.
I am thinking about applying a layer/coat of some sort of "sticky" or "coarse" material both on the surface of the platform and on the underside of the recliner's circular base, so that friction between these surfaces is maximized and slippage avoided.
...MY QUESTION IS: Can you help me with ideas on both approaches and/or materials to be applied in order to avoid recliner slippage on a platform hot-rodded with built-in shakers???
NOTE 1: In principle, I feel like not to impact the integrity of the recliner's circular base; so I am not considering drilling holes through it in order to get the base bolted to the platform as a first approach. Instead, I feel like exploring first the options for maximizing friction between the platform and recliner contact surfaces.
NOTE 2: The Berkline model 729 recliner has been apparently discontinued from the Berkline catalog. However, it looks very similar to the model 668 recliner, which is currently shown under the "Leather Recliner" category at the web site ( http://www.berkline.com/ ).
Hey, thanks a lot, fellows, for all the ideas you can come up with!
J.V.
J.V.
