Status
Not open for further replies.
1 - 5 of 5 Posts
Hi.
My HTPC has 800mhz, and use a Radeon 7500 with HW acceleration.
My question is: if I use a 2ghz processor instead, will there be any
upgrade in quality? This is for DVD use.
Another question is: will Dscaler(for LaserDisc) be better at 2ghz than
800mhz?
Thanks for your time,
Nicholas
Discussion Starter · #2 ·
Bump.....I'm about to buy, if needed...
Nicholas
Discussion Starter · #4 ·
So it won't help DVD at all? hmmm....Will it be worth it for
LD's alone....Maybe, maybe not..
Dscaler is very CPU intensive, especially when you start turning on various filters and features. I feel a 2GHz processor is probably necessary to get the most from Dscaler... (ie. no dropping frames or having to disable things or reduce quality such as decreasing pixel width). As for DVD viewing, your current (800MHz) processor is way more than adequate (even with H/W acceleration off)... that is... unless you add ffdshow to the line up! If that's the case, you're back to needing all the CPU "horsepower" you can afford. Again, I would suggest that 2 GHz would allow you to get ~2 filters going before 'running outta gas' (most people only use either a 'sharpening filter' and/or the 'blur and noise' filter).
...anyway that's just my opinion.
1 - 5 of 5 Posts
Status
