Hi Jeff,Recent stuff:
1. I just purchased some used Crestron T-STATs on eBay that are Crestron Home Compatible. Let's see how these work?? Stay tuned...
2. I had some compatibility issues with Apple TV only displaying @ 1080P but this was fully resolved by a firmware update on my NVXs. Now all 6 sources are solid sending 4k and HDR to all TVs. Excellent fast switching.
3. Sequencing addition to macros is really making the system work nicely. If door bell is rang, it will now flash lights in the theater to let me know someone is at door. Pretty cool. I do not have [yet] Crestron Home in my theater is there is no programming yet for Trinnov (IP or RS-232), Lumagen (RS-232)... waiting for someone to do a custom driver. That's all I need. Then I can convert my Crestron TSR-310 from old Crestron CP-3 programming to Home. Sony PJ is in list of Crestron certified IP products as are all my other sources (KScape, Samsung BD, Apple TV).
Hi BryanHi Jeff,
I have been using Crestron cresnet wired T-Stats, and they have worked great. I have about 10 zones of HVAC in the house. When have the electrician on site for replace my generator, I am going to get thing wired so I can use the DIN-THSTATS and a thermostatically controlled relay to control the heated floors in 3 of the bathrooms. This is a bit of an experiment
What version are you using on your NVXs are you using. I have a problem with my XBR-65A8H and KSCAPE thinking it cannot play HDR content.
Glad to hear of your success.
Hi Jeff,Also, did you install a Crestron DDNS for remote control away from home?
Hey!Hi Jeff,
Sorry I missed this. I have a static IP (reserved IP), and I have a domain registered and host name for my crestron home system. My domain and DNS is all through Go Daddy.
If your ISP will provide a static (reserved) IP address, I would definitely recommend that. With my ISP it costs about $10.00 per month.
Jeff,Hey!
I’m not a tech guy. What is the advantage of a reserved IP and domain in this situation?
Also, so is your DDNS thorough Crestron (Crestron DDNS as seen in settings) or you set up your own DDNS through godaddy? I thought to have remote access to Crestron Home, I needed a Crestron DDNS... so not needed?
Remote access does not require Crestron DDNS, but that is a great option without a static (reserved) IPHey!
Good to know! IF you have a minute, send me a note and we can chat.Remote access does not require Crestron DDNS, but that is a great option without a static (reserved) IP
I have done it quite a bit. CHV-TSTAT are a Cresnet device, wire them into the Cresnet bus on the processor and they should all show up in the device list un Cresnet devices.NEW
Anyone install Crestron Thermostats into Crestron Home??
I have bought Crestron CHV-TSTATs for around the house. Any tips on installation? Thanks!
I am curious if there is any benefit you know of going with a static IP from the ISP versus using a DDNS service? The main reason I can think of is less work on the initial router configuration, but once its setup it doesn't need to ever change. I have always gone the DDNS route as a static is not available through my ISP for residential service, so I am using a pro DynDNS account which is currently $99/2years.Jeff,
With a reserved IP address your router will ALWAYS get the same IP address from your ISP.. In that case you don't need to use Dynamic Domain Name Services (DDNS). You can now use standard DNS (Domain Name Services). If you go this route you can go to Go Daddy and purchase a domain. Say something like thebland.net. If you are interested in this I can give you some recommendations (things like a private registration) so spammers and other don't pester you. Once you have purchased the domain, GoDaddy or other domain name registrar will provide you domain name services. You can then name your system like myhome (myhome.thebland.net) you will then associated this name with your reserved IP address and now instead of entering your IP address you can enter myhome.thebland.net. There is no requirement to setup a domain and DNS if you have a static(reserved) IP address. I just tend to personally prefer setting up DNS for external access purposes.
Let me know if you want to discuss and I can give you a call.
Bryan
