Well, the speakers seem to be sensitive at 90 dB spl. Min impedance of 3.1 Ohms @ 2.45kHz where power need is not much, so that 100W Yam should be fine.
+2You're happy, be happy.
For a 2.0 system with no need or desire to integrate a subwoofer I think you are good to go.Speakers - Audio Monitor Silver 500
Stereo Amp - Yamaha N303
Turntable - Rega Planar 3
Cables - Monoprice 14 gauge
Room is 28' x 15'
I think my speakers and turntable are great. I recognize the Yamaha is a budget, and thinking of upgrading (Mcintosh MA352 is a dream product but too $$$ to justify at this time). Honestly though, I like the connectivity of the Yamaha (Bluetooth and Airplay 2 in particular). I also recognize diminishing return on any upgrades - music sounds great to me and don't have any problems, just mild upgraditis. One other idea I'm toying with is a subwoofer (SVS SB-1000 Pro in white to match speakers and turntable). Not an audiophile by any stretch, but up for anything that will get me listening to more music. I think I would add subwoofer and save up for a new integrated amp.
Perhaps instead of the McIntosh MA352 ($6500), the MA252 ($3500) integrated amplifier may someday be within reach.I recognize the Yamaha is a budget, and thinking of upgrading (Mcintosh MA352 is a dream product but too $$$ to justify at this time).
Thanks Mashie - apologies to Monitor Audio! They are great speakers.I think your speakers might be upside down if they are called Audio Monitor and not Monitor Audio.![]()
Thanks Alex - I think the MA252 is a great idea. I had it in my head that I would go big and get the MA352, but in reality, I'm sure the MA252 would more than meet my needs (as does the Yamaha as CharlesJ pointed out). I will be the first to admit its mostly for how cool it looks (sucker especially for the nostalgia of the meters on the MA352).Perhaps instead of the McIntosh MA352 ($6500), the MA252 ($3500) integrated amplifier may someday be within reach.
The MA-252 is a good choice. Also I would check out the Luxman 505uXII. Would also make an excellent match w/your speakers.Speakers - Audio Monitor Silver 500
Room is 28' x 15'
There's your answer. Money spent on solving problems is a wiser pursuit. Or save it and upgrade your investment account."music sounds great to me and don't have any problems"
So all Monoprice 14 Gauge wire is CCA?I have never been a fan of CCA speaker wire.
No.So all Monoprice 14 Gauge wire is CCA?
What's there to critique? That setup looks killer to me.Speakers - Audio Monitor Silver 500
Room is 28' x 15'
