I see over and over on the forums about the look of the old CRT and how the flat panels out as of now will never look as good.
I have been thinking alot about this and often go over to the 20 inch crt sets my kids have and look at them vs my new 52 on SD channels.
I think many people have this on a pedistal feeling toward CRT.
Granted the blacks were better on some CRT but that certainly wasnt all of them. After going back and forth to the sets and looking very close at the small sets I can tell you the following.
The same defects you see on your giant flat panel LCD or Plasma are there on the 20 inch CRT. The CRT just covers the noise and defects more because the image is blurred from the inherent lower resolution technology. Also I believe that the CRT in most case has much brighter whites than the Larger panels. this isnt because we cant drive the panels that bright but because if we did we would burn out eyes out on the larger screens. This brighter white tends to hide the defects in the signal more.
I actually think more people calibrating thier sets is allowing people to see the defects in SD TV alot more than previously. I believe in CRT days people took thier sets home and watched them Overdriven contrasts and all. And this hid alot of the bad image.
Sure there used to be huge SD projection sets and they looked awesome. Have you gone to a friends that still has one or a bar and seen one lately. BLUUURY and dim. Again hiding all the defects.
Another contributing factor to new sets SD looking bad is stretching the image. Now I am guilty of this because the wife hates the bars but when you have the bars and watch a 4:3 SD picture in 4:3 the image is actually startlingly good if you go and compare the same signal on a little 20 inch CRT. You will find the same garbage in the image on the 20 inch CRT at close range.
Overall I think the biggest issue vs an old CRT is more people putting it on a pedistal and black color combined than it is actually worse. In almost all ways I can see comparing the 2 set types the Flat panel technologies are actually better.
My 2 cents
My 2 cents
