Status
Not open for further replies.
1 - 8 of 8 Posts
Banned
I have a RGBHV cable I got from AVcable that is BNC to BNC. Is there no BNC ouput? All I see is DVI out. Why can't I begin to setup a resolution on my pj when it says progressive in and 720p RGB out? my dvd is hooked up correctly. My RGBHV cable is into my NEC 6PG Plus (6100) pj and i'm trying to add a new signal. Please help. :(
Banned
Discussion Starter · #2 ·
Is there something wrong with my pj if I see no menu or anything? I have it hooked up to the bottom right set of inputs under interlaced the c output is going into the h/V input on my pj and the others I kow or correct. Do I need to do something with it on my computer first?
Is this the issue where I must select H/V?
I need ot go to school now.
Later
- Steve
Banned
From what I remember from the Centerstage, it doesnt have RGB 5 bnc out. It has a RGB vga out. You are going to need a vga - 5 bnc breakout cable. I am assuming that your projector has 5 bnc input. On the setup menu, you are going to have the tell the Centerstage that you want that vga output to be RGB and not component. It gives you a choice
Banned
Discussion Starter · #7 ·
I got a Bettercable this time. It will be shipped the overnight method again but be here on moday I think.
- Silver Serpent® VGA Breakout
Connectors: hd15 Male/5 BNC
Length: 5 m (16.40 feet) (+70.00)
1 - 8 of 8 Posts
Status
