CT-34WX54 color settings
316 Views 1 Reply 2 Participants Last post by  troublefan
Hi all.
I have posted this same question a while back and the color scheme still doesn't look good.
Does anyone have a color setting they used that reduced the red and made the color just right?
My eyes are really lousy with calibrating TV. I even used those color calibration DVD's with no help.
Thanks a million!
David
Status
Not open for further replies.
1 - 2 of 2 Posts
I did my 34WX54 just by sight then with Avia, and they came out similar. Now, everyone's perception is different, and these are merely the settings I have mine at, so they may not (probably won't) work for you. I've had one person say these were really whacky settings, but I've had others say that, after your eyes adjust to properly set colors and pictures settings, it's close to what normal (true) color is supposed to look like. Good luck and remember, your results may vary:
Color 17
Tint 40
Brightness 54
Picture 40
Sharpness 3
Color Temp-Normal
Natural color-On
Video NR-Off
VM-Off
MPEG NR-Off
See less See more
1 - 2 of 2 Posts
Status
