Status
Not open for further replies.
1 - 6 of 6 Posts
I'm not sure if this is the right forum for this question but I'll try anyway. I'm building a new house and am having a custom cabinet built for a Sony 51", speakers, equip., etc.
1- If I make the dimensions to house the tv larger so that I could get a larger tv down the road, what's the best way to cover the extra space between the cabinet and tv (i want the tv to be framed in the cabinet)?
2- My Sony has a toekick and I want a false front to frame the screen. I know I could remove the grille to the tv but a toekick still exists and there are holes that are open to behind the screen. I prefer not to get dust inside. What I my options?
Premium Member
You don't want to make the enclosure airtight. Things get too hot. If dust is a worry. Put an air intake at the bottom of the cabinet. It can be on the side or have a grille covering it. The intake area can have a filter behind it. Put another opening at the top with a fan exhaust.
A wood bezel can be created to cover the front of the TV and leave an opening large enough to accomodate a future larger set. The stiles, rails, and panels of the bezel can be designed to look attractive for the present and redesigned and rebuilt to contain a future screen. The major parts of the cabinet would be unchanged and only a new bezel would be needed for a new TV. See my gallery for an entertainment center with a removable bezel.
Clone1-
While Pat's recommendation to cover all but the screen does net a clean look, you must ask yourself "Self, how much larger of an RPTV would I want, or would the upgrade even be an RPTV?"
A customer of mine just got the brand new Mits 73" RPTV, That sucker is huge! To the tune of about 500lbs and very deep as well. His remodel incorporated a recess in a wall so as to not sacrifice so much floor space in the room.
The second part of the question, is critical, think how much your are spending on housing a RPTV, when a future upgrade may very well be a front projection system or even a plasma. If you are considering upgrading in only a few (couple?) years is it economical to spend the money on custom cabinets they may or may not be adaptable to future (needs?).
I have personally done retrofits, for built-in cabinets that were not designed for future needs...A) It's a pain in the ass (cutting and fitting) B) It's expensive to the customer and C) It's having to work with what you've got (compromises) to net a decent look.
Sorry to sound a bit negative - but I get far less calls for RPTV cabinets these days and I try to recognize what the future trends are to be.
Good Luck,
Bruce
Originally posted by Clone1
Bruce,
What would you suggest instead?
It would help to know more detail of your individual circumstances, ie. layout of the room etc. But I will throw a couple options your way in the mean time-
-If the design you seek calls for custom cabinets (woodwork etc). you might consider free standing furniture. Where it would be built in a modular fashion to accomodate expansion. Side cabinets for electronics or display items and a bridge for over the RPTV. And the design of the side cabinets could be such that they would work on there own (w/o a TV).
-If the design you seek calls for a built-in look, then maybe consider a secondary false wall with sheetrock, studs & paint to house your elements. It may make future upgrades (of a yet undetermined variety) easier to incorporate, since it would be cheeper to just cut away parts and re-paint.
Any idea as to what you perceive as your short list of upgrades?
Bruce
Discussion Starter · #6 ·
Bruce,
My upgrades would be either a larger RPTV or plasma. The wall is 14ft. long and I would like to go with woodwork. We have a freestanding unit right now, but we do not like it. I do know I want everything hidden. I have Sonance RS-1's for my surrounds (in ceiling) and the hidden aspect is very important to me. I have designed the built-ins and they go like this:
-Middle section with cabinet space above the tv for the center,etc. The cavity for the tv is larger to accomdate future.
- Left and right cabinets to house slide-out Middle Atlantic racks, DVD storage and Front/Left speakers.
- Bookcases would flank these with one bookcases lower cabinet housing a front-firing sub.
1 - 6 of 6 Posts
Status
