When I suggested putting a curved screen, such as a Torus, into my theater, my installer said that I would require custom ground lenses on my projector. Apparently his reasoning is that the lenses are designed for a flat screen, and the new geometry will be sufficiently different from flat that there will be distortion or convergence problems.
My projector is a Sony G90. I can readily imagine that I may have to relocate the projector to ensure I have the right throw distance to a curve screen, depending on where it is mounted. But I'm a little surprised that there would be other problems, or at least problems that can't be corrected with the projector's built-in adjustments. Is my installer correct, does a curved screen require a lens with different geometry?
