Hello Ladies and Gentlemen,
I wanted to let you his know that as part of my antibordem campaign/new gear fund I will be making custom length to order shielded RCA cables (theoretically useable as component) out of acoustic audio cable and some nice good plated "monster" cable RCA connectors straight from China, or more costly neutrik brand. The acoustical cable is good, solid monoprice 8mm, no secrets here (copper shielded, 2 conductor, aluminum reinforcing strand it appears also). For rca purposes the inner wires are soldered together, as is the copper shield and 5 strands of aluminum reinforcing wire. Then the RCA connector is tinned and the connections soldered and given my tug of approval/test on the amp.
I can also make xlr connections.
These services are for people in Nooo rush as I Iive in Canada eh. If anything becomes of the service I will make sure I support the site
this place is amazing and a serious part of my contiued rehab.
Cost for the RCA cables start at a fiver per cable plus a buck a foot, then whatever the heck shipping to your house should be (I'll use Canada Post cheapest option with tracking so brokerage to USA should be nothing).
I can solder up just about anything you want if you have other ideas for me.
