Status
Not open for further replies.
1 - 4 of 4 Posts
Discussion Starter #1
I had the pstrip with some custom R&T. Later I exchanged my Radeon with 64MB retail (I had the 32MB earlier). Since the installation of the new board, some how the custom resolution table is gone.
I heard some of the Radeon drivers do not allow custom res vis the pstrip. Is this a fact and causing the problem?
I guess I still can do the custom res & t through pstrip.ini, but would like to hear your opinion about this discrepancy. Thanks a lot.
Discussion Starter #2
Anyone please?
You need driver version 7089 or 7093 to do custom T&R with the Radeon. If you reinstalled the software from the CD, you need to (re)install one of these beta drivers.
Also, you may need to set up the custom resolutions again in Powerstrip. Use the Add Custom Res. button to reinstall the settings you use. Then you should be able to use them with the regular Powerstrip tools.
No boom today. Boom tomorrow. There's always a boom tomorrow. -Ivanova, B5
Discussion Starter #4
Thanks. It helped a lot to know what is going on here.
1 - 4 of 4 Posts
Status
