1 - 4 of 4 Posts
Hi,
inspired by home theater gurus tutorials and diy threads from avsforums, i started to think of building a diy marty or hammer sub. also due to very high prices of subs in India (pb 16 ultra costs 5000$) diy sub was the best choice. i have modeled the sub using winisd and marty excel calculator. crown xls2002 in bridged mode and minidsp hd for amp and dsp. pairing this sub with my old rsl speedwoofer 10s.
i have used screws and wood glue to join the panels. work is done through a local carpenter using 0.7inch mdf .
this is the model
Rectangle Slope Font Screenshot Software
3157009
3157010
is 19-20m/s fine for this build?
some build pics
3157011
3157012
Wood Rectangle Wall Wood stain Hardwood
3157014
Wood Gas Font Automotive wheel system Circle
tripple baffle with some support
3157016
Electronic instrument Audio equipment Carbon Gas Sound box
dimensions- 35inch H/24inch W/28inch D
waiting for the paint, crown xls2002 amplifier and minidsp hd to arrive.
is spray can paint be enough for this? is foam lining required?12 awg wire is double the price of 14 awg in my place, so 14awg for 20feet run and to wire inside the sub would be fine?
  • Like
Reactions: xb1032
I believe 19-20m/s is fine. I have subs with higher port velocity and sit near them and I don't hear chuffing.
I read another post who bought a pair of martys and lined one with expensive lining and the other with nothing and couldn't tell the difference. GSG doesn't list foam lining in their assembly checklist for the Martys.
Discussion Starter · #3 ·
Ya in their checklist they dont mention this,i was wondering why svs or manufacturers use foam lining in ported subs?
Venu360, Niles power Amp, Emotiva power Amps, Crown power Amps, Yamaha CX-A5100, DIY speakers, UHZ65
Absorbent material behind the driver is for much higher frequency. If you look at the damping effect of most materials they start in the lower midrange area and go up.
If you are trying to dampen and overdriven driver it is possible to get higher frequency content as distortion. Not going to help what comes out from the driver directly into your room though.
1 - 4 of 4 Posts
