I've been lurking here for ~2 years; while I pondered how to finish my basement (and if I was up the task)?
After seeing the many succesfull projects on these forums, and the tremendous support and resources - I decided to go for it!
So I will start with a link that shows my earliest efforts of using sketchup. As you can see this is a large open rec room with a theater area. Yes; this is a compromise - trading acoustics potential for a larger more flexible space room:
http://i227.photobucket.com/albums/d...youtSketch.jpg
The bottom of the sketch shows the area that is already under construction, the bathroom and potetnial bar area - thought I would take on the most difficult task first:
http://i227.photobucket.com/albums/d...1-6181_IMG.jpg
The following links show my temporary "proof of concept" front PJ set up. I am using an older (free) HP/Optoma DLP, and a home made hanging screen. The idea was to test the WAF & get the family buy in. Whenever I get finished, 1080p projectors should be quite affordable:
http://i227.photobucket.com/albums/d...1-6148_IMG.jpg
http://i227.photobucket.com/albums/d...1-6146_IMG.jpg
http://i227.photobucket.com/albums/d...1-6191_IMG.jpg
Thanks For Looking!
Thanks For Looking!
