Status
Not open for further replies.
1 - 4 of 4 Posts
Discussion Starter #1
Resolution switch problem............
When I set my D* H10 stb to resolutions all / native on when I change channels that change resolution the TV is not switching. All I get are ////////////////// lines.
Help please.
So the box resolution is changing and your TV isn't syncing up to the change?
Discussion Starter #3
Yes exactly. If I run the tv throught input changes I get the pic back but that's the only way.
Display is the new sony E50A10 using side input 2 w/component.
Sounds like more of a TV problem, might just want to run the resolution fixed out of the H10.
1 - 4 of 4 Posts
Status
