D-Link DIR-655 Extreme N Wireless Router for wireless use with the PS3
2631 Views 24 Replies 10 Participants Last post by  kana3883
Hello,
I will be switching from DSL to cable internet tomorrow. As a result my Zoom 5590 X6 combo modem/router will become useless. The cable company will be providing a modem. However I will need to buy a new router on my own. I currently run my PS3 wired, but the kids will be getting their own PS3 which will be in the front room of the house.
I would like to run their PS3 wirelessly. The router I am looking at is this one: D-Link DIR-655 Extreme N Wireless Router. Does anyone have any experience with this router in general and in specific for wireless and wired use with the PS3? In addition, how is the wireless range on this router? Any additional comments on ease of setup, reliability, etc are more than welcome as well.
I posted this in the Home A/V and networking forum as well. I'm not sure where the better spot for it would be to catch a bit more visibility. I hope that's not in violation of good forum etiquette.
Thanks in advance.
1 - 20 of 25 Posts
Originally Posted by SharpOne /forum/post/16877221
Hello,
Thanks in advance.
I have this router and have recommended it for my friend (which I setup for him).
It's a great router (though, you may want to make sure you have the 1.32 firmware, not the 1.31...the 1.31 sometimes reboots itself. Found this out because I configured my router to email me logs every day).
For my house, I have it setup via wired methods, running my PS3 to the wall, which goes to my router in the enclosure in my closet.
For my friends' place, he is using wireless. Their router is located upstairs in their office, while the PS3 is downstairs (it's a town house, so there's not much distance to travel).
Setup was a breeze, if you aren't looking to a complicated network setup. Mine is setup with a lot more security than my friends' router, and both work fine.
Range of wireless is pretty good. I use the wireless for my work laptop and my wife's laptop. From our kitchen, which is almost directly below our enclosure, I get almost full signal strength.
However, from my den, my signal is pretty weak. Some things to take into consideration:
1) My work laptop's wireless is crap. It's routinely saying that it lost the connection to the network...even from the kitchen. I know it's not the router, because my wife's laptop has never shown this.
2) My den is, quite literally, on the other side of the house and down a floor.
In my opinion, you can't go wrong with this one. I haven't had any problems with the router that a firmware couldn't fix. Likewise, my friend hasn't complained about any issues either. I got mine a month or so after the router was released (Q4 2006). My friend got his last year (I think?).
There's another thread here that discusses routers. There are more reviews on the DIR-655 there.
See less See more
PS3 is only wireless G speed so an N router is probably a waste. The Dlink does have gigabit ports in case you change your mind about wiring the PS3, it also has gigabit ethernet.
Not much else to say. Still one of the best routers around. Been using the 655 for 2 years now.
Very good experience thus far with the DIR-655, especially after the newest firmware update.
If you also pick up an N wireless access point, you can plug that into the ps3 to achieve N wireless speeds...little extra cost, but useful if you want good speed but need wireless.
They said that they were going to go wired for the PS3 they were going to use, and wireless for their kids' PS3.
i also own the DIR-655. works as expected
doh, looks like I had the dates wrong. They will be here tomorrow.
Thanks all for the comments. It sounds like it's a pretty solid router in both its wireless and wired configuration. Although there seem to be some mixed opinions on it on Amazon.
Does anyone have any other comments on its wireless range? Is anyone operating it wirelessly in tandem with their PS3 inside a AV cabinet?
Do you happen to know what the latest firmware update number is? Also, are you using one of these N wireless access points? Lastly, any thoughts on which one would provide easy/good compatibility with this D-link model?
My friends' have their PS3 on the hardwood floor, nothing blocking any signals.
I mentioned in my first post that the latest is 1.32NA.
Thanks for the quick reply ppshooky, sorry I missed that firmware number in your previous post.
I forgot to mention that some of the user reviews state that this router runs hot. Yet, one user had a picture with a Slingbox on top of it. I would think that if it ran that hot, you wouldn't want to put another piece of equipment on top of it. Anyone care to comment?
Mine's in an enclosure in my closet. It's cramped in there with all the wires and such, but I haven't had anything shut down on me due to overheating. Even on a 90 degree summer day.
It can get pretty warm, but certainly not skin-blistering. I've handled the router after I had just unplugged it.
Depending on what you want to do with the PS3, wireless N may be a waste. Don't plan on streaming HD movies with it. For just regular PS3 gaming and updates, a wireless G router should suffice.
I got nothing against the DIR-655, I've had it for over 2 years now.
I don't have any hardware that uses draft-N, but I still bought the router.
Considering how many awards it on over the last 3 years, I think everyone should consider it. Even if it's 3 years old.
Plus, now, they are selling for pretty cheap.
I have this exact router and its great, you have room to plug up to 4 things into it, as well as a near infinite wireless connections as well. I live in a cement box and have no issues of the signal travelling from my 2nd bedroom to my living room where my PS3 is located. The WPN codes are SUPER long though, make sure you double check it when entering it!
Just providing a little update/feedback on this router for other's future reference.
I'm running this router wireless to the one PS3, and to 2 laptops when they are in use, and everything looks to be working quite well. Signal strength to the one PS3 is 100%, which I would expect, as the router is only about 10 - 15 feet away, with only the cabinet wall the PS3 sits in, and a couch in the way.
I did conduct a trial run in the second location, where the kids PS3 will go, and the signal strength, as measured by the PS3 was only about 60%. That location is probably about 40 - 50 ft away, plus a few walls (plaster...it's an old house). In spite of this, I downloaded one of the longer epsiodes of Pulse. It was about 400 Mb. No problems at all. I didn't test out game play in that location though. I thought I read somewhere that the PS3 needed a connection of at least 80% to be reliable. We shall see.
If that is the case, I guess I'll have to get a wireless bridge or wireless access point. I can't really move the router to be more centrally located between the two rooms.
Does anyone know if a bridge or access point will be capable of taking a lower strength signal and boosting it in that location, or will it just relay that lower strength signal? I'm not sure if I worded that right.
Lastly, download speeds are vastly improved from my old DSL. If you are stuck on the 1.5 - 3 Mbps DSL like I was, man what a difference a jump to 16 - 22 Mbps cable makes. It used to take me like 1 to 1.5 hours to download a 1 Gb sized demo off the PSN. Now it takes like 8 - 12 minutes.
See less See more
Powerline Ethernet would be an option as well. 5 min super easy set up (including the walk downstairs) with rock solid performance.
Anyone had any experience with these Ethernet Powerlines in older homes, built 1950 or so?
The good: My house was built in 1990. My PC, cable modem, D-Link DIR-615 are upstairs, PS3 is downstairs ~ 30ft away. Works great for streaming and even watched a locally blacked out NFL pre-season game via the internet last night with acceptable picture quality.
The not so good: A friend with a very nice 2004 built house, couldn't get acceptable speed between two PC's located ~20' apart on the same floor. He returned it.
Both were the Netgear AV101 that I linked to above. The Amazon comments are generally very positive. Considering the wide variations in house wiring, breakers, ciricuit locations, etc... The only way to know, is to try it in your particular situtation. With a good return policy and no effort to install, it might be worth a try.
I've seen it used in a home built in the 1920's, speed may not be as fast, but it seems to work from what I can tell. Just buy it from a local store to verify it works and if it doesn't, send it back. Having a reliable 200Mbps connection is a lot better than an unreliable (wifi) based one IMO.
-Splints
1 - 20 of 25 Posts
