After logging about 50 hours on my JVC deck, I figure it's overdue for a cleaning. I have heard the JVC cleaning tape is not good. How is the Maxell VHS Head Cleaner (Wet, VP-200)? It's not marketed as being compatible with D-VHS, so I don't know if this is a good option or not.
I remember an older post that had detailed instructions for manually cleaning the unit by removing the cover, etc. but the search feature doesn't go back too far. Any help would be appreciated with advice for cleaning this thing.
