Status
Not open for further replies.
1 - 4 of 4 Posts
· Registered
Should da-lite hi-power material be tensioned to achieve the best results? I know that da-mat needs to be tensioned to be kept flat. I've heard that the same is not true for hi-power.
· Registered
I have the hi-power in a model-b manual unit. It has small waves on right hand side that are not visible at all when in use. The retro-reflective material makes the difference.
Tom Pfarr
http://www.toad.net/~tpfarr/Hometheater.htm
· Registered
I second that! I feel one of the major benefits of this material is that tensioning is not required making it very inexepensive. Great screen to use with a Sony 10ht
All your bases are belonging to us since 1902...
1 - 4 of 4 Posts
Status
