Originally Posted by ertang /forum/post/0
hi! i'm already planning to buy a tensioned screen 106" hdtv at projectorpeople..but first i'd like to know if its a good combination? will i get a good quality? hope someone could help me..thanks so much!
Originally Posted by BobL /forum/post/0
The environment you will be viewing would be the primary factor on the type of screen material to use. We would need more info to give a better recommendation.
Originally Posted by Sax /forum/post/0
I tested all the Da-lite screen samples, and I went with the Carada BW screen.
For your situation I'd use the CV unless you plan to watch with some lights on then the HCCV would be the better choice.
