Status
Not open for further replies.
1 - 4 of 4 Posts
Premium Member
I live in North Dallas (Tollway and Westgrove) and have been
struggling for two months to get all of the network off-air
DTV broadcasts to tune through my Dish 5000/HDTV Modulator
and Panasonic DST50/PV-HD1000 setup. HBOHD is, of course,
exceptional when viewed on my Sampo, but it's network HDTV
off-the-air where most of the daily and sports HDTV
entertainment can be found.
The apartment complex master antenna wouldn't pick up the
UHF digital channels, so I had an outdoor antenna installed
in my attic. I live on the second floor of a 2-story wood
apartment building and concealing the outdoor antenna in
this way seemed like a reasonable idea, given that I was
fortunate enough to have that option.
Unfortunately, this turned out to not be a very successful
idea. After the attic antenna was installed I could only
receive 4/35 (FOX), 5/41 (NBC), and 8/9 (ABC). I could not
receive 11/19 (CBS), 21/18 (UPN), 33/32 (WB), or 13/14
(PBS).
I had the Goodman TV people come out a second time to see if
re-aiming it slightly would make a difference, but it did
not. I had been skeptical that a general purpose broadband
Winegard Ghostkiller was the proper antenna anyway despite
its $129 price, and this experiment in futility proved it.
There is a real problem shooting south down the tollway to
where the transmitting towers are (in Cedar Hill), because
of all the new buildings that have gone up recently and
reflections coming north through downtown.
I then looked in the yellow pages for antenna specialists,
and after calling several companies who couldn't help me, I
stumbled onto an outfit which really seemed to be true
professionals. At least they talked a good game on the
phone.
They are B&H Commercial Services (214-357-1947) and seem to
do lots of building and high-end installations, according
to their own references.
Anyway, they recommended I buy a "GE Max" antenna for $99,
as a first try. This is an unusual tube-shaped DTV antenna
which had solved a similar problem for another customer
in my area. It can be mounted vertically or horizontally.
In worst case, if that didn't work, I could then try a much
more expensive Terk. Both the GE and Terk antennas are the
outdoor powered type, utilizing a power injector inside the
house where the coax connects to a receiver. But it was
recommended that I should try the GE Max first, as it was
less expensive and had been known to work successfully.
The GE antenna is sold through Jasco Products, which is the
retailer for GE products (I guess). The particular antenna
I bought was the mode 94757, which is a 6 foot tube (made
of some type of composite material it seems) with plastic
mounting brackets, good for 60 miles. The coax output
connector is imbedded at one end of the tube.
http://www.jascoproducts.com/cgi-loc...html?E+scstore
(go down a bit in the page, and click on the link for
"Max" The Ultimate TV Antenna System)
Ok, I bought it, and B&H came out today to do the install.
We tried various locations on my roof and near the chimney,
and finally settled on a location facing due south. It was
mounted right near the peak of my roof lying horizontally,
almost at the highest point on the roof and with a clean
shot at the south sky, with no other buildings in front of
it. Because it's resting horizontally on the roof, it can
barely be seen unless you knew to look for it and where.
And, like a miracle, I can report that in addition to the
NBC, ABC, and FOX network DTV channels that I was receiving
before, I can now also receive the DTV versions of CBS, WB,
and UPN! I still can't receive PBS however.
This antenna is fantastic... for the price! Whatever the
problem with CBS was with the Winegard, it's gone now with
the GE Max.
Also, the GE Max can actually pull in the analog VHF and
UHF stations, although not too well. In fact the Winegard
antenna does a much better job on the analog side. But
neither of these problems affects me as I get the local
Dallas network station package through Dish. I only needed
the off-air antenna for local DTV/HDTV as I watch local
networks from the satellite.
So I'm recommending VERY highly the $99 GE Max "tube"
antenna for anybody who needs a "modest" antenna solution
and can put one outside. Naturally, the higher the
better. Vertically or horizontally, whichever works best.
I am now THRILLED to be able to receive CBS DTV, as they
are broadcasting 3 prime time hours each night in HDTV,
not to mention sporting events.
D Sperber,
Thanks for sharing your experience with the GE MAX Antenna. I have been skeptical of the claims made in various ads, but your experience with this antenna is very good.
I understand that this antenna design is patented but I have been unable to find the patent #. If you still have the box the patent # ought to be printed there somewhere, or maybe on the antenna itself. If it's convenient for you I'd sure appreciate getting the patent # or #'s.
Premium Member
Discussion Starter · #3 ·
Although I still have the box (hadn't gotten around to
throwing it out yet) there's no mention of a patent number
on it.
I also checked the installation documentat and again it is
void of such a reference.
If you want, there's an 800-508-6532 number you can call
to get tech support for installation. They might be able
to give you more details, possibly the patent number.
One more note. Having also learned from the CBS-DTV guru
here in Dallas that they actually had an incompatibility
problem with Panasonic STBs and were finally fixing it over
Memorial Day weekend, I wondered if my previous inability
to receive CBS-DT through my attic antenna was really
caused at the transmission end, rather than because of my
antenna.
Strangely, late Friday the CBS-DT signal (which I had
previously mentioned I could now receive) appeared... like
magic. I assumed CBS had actually done the hardware
upgrade ealier than they told me, since even with my
GE Max antenna installed earlier in the day I had not
been able to receive CBS-DT. Otherwise, I can't explain it.
Anyway, over the weekend I tried to get CBS-DT from my
attic antenna and was unsuccessful. I also could still not
get WB-DT and UPN-DT, both of which are achievable using
the GE Max.
So whether or not the appearance of CBS-DT late Friday
was genuinely due to something at the transmitter end or
not, I still can get it now along with WB-DT and UPN-DT...
but only with the GE Max.
1 - 4 of 4 Posts
Status
