1 - 7 of 7 Posts
Discussion Starter · #1 · (Edited)
as of the post ther all out of stock but when ther in whick would be the best woof for the buck
currently plan to drive via my xls 1502 in a ported 3.8cft cab tuned to 18hz in winisd iv modeled all three for my cab design only the fi's need any eq to flat out the fq curve
cab design has a planed 45in long 12in wide by 2.5 flair port
3156695
3156696
3156697
3156698
3156700
this would be a layered mdf cab with front an back panels 1.5in thick an port wall 1.75in thick out an outer sides 2in thick with an inner dim of 30in by 16.74in by 12in
counting the space before port entrie is 16.74in 12in by 5.5in this give a totel net air factoring driver displacement of all three driver options of 3.755 cft3 to 3.85cft3
the cabs outer would be 38in h by 15in d by 24in w
the planed port postion in downward placed on a 6in custom attached stand from mdf scrap with a 1.5in foot with a .5in rubber pad
3156717
3156718
the cabs would be mirrored to either side of my ht room an 1in out from the wall
to winisd models an wdr files
IMO, that's up to you to decide. Also, not sure about the decision to load a driver that's intended for IB into a very small ported cab :unsure:
It would also be helpful if you'd post your WINISD models.
IB=Infinite Baffle
1 - 7 of 7 Posts
