Summary:
A long time ago this thread about a DBX PA2 clone caught my eye. It was a pretty neat piece of gear, providing solutions for many of the pet peeve's (phoenix connectors, lack of network control, wallwart) of the MiniDSP platform that caused me to come up with my own custom solution. At the time I was planning some upgrades to my unit to add network connectivity via a WI-DG, as well as limit noise via a miniDC Isolator. I was also thinking about replacing the wallwart with either a better one, such as the iFi iPower DC Power Supply or going all in with a linear powersupply (example 1, example 2)
After purchasing both the WI-DG and miniDC Isolator, I learned the hard way that the WI-DG is not compatible with either the 2x4 RCA or 2x4 Balanced (the 2x4 HD and most other newer models are). I remembered and revisited the AVS thread, and then really dug into research mode about the PA2 to see if it would be a suitable replacement, if not upgrade to what I was using.
I found a lot if information out there, including walkthroughs of the software and reviews of the product and its possible applications. These really helped me in evaluating the PA2 prior to purchasing, however it also lead to a bit of analysis paralysis. After quite a bit of research I decided that I just needed to dive right in and grab one. I also thought that perhaps others may find the information I'd gathered useful.
This particular post is more of a feature and cost comparison. Additional posts will cover results/observations. For those wanting to do their own research, see the research section at the bottom of this post for links to reviews and videos.
Disclaimer
Before we go any farther I feel the need to clarify a few things.
When contemplating a purchase, I like to make Pro's and Con's lists to try and understand what I'm gaining or problems I'm solving, as well as what I'm losing, or problems I'm creating. The list below is what I came up with for the PA2. Since I already had the MiniDSP, and it would cost me 0 dollars to keep it, I felt it made sense to start with the drawbacks of the PA2 rather than the strengths.
DBX PA2 Cons:
Cost differential:
DBX PA2
MiniDSP
Cost Summary: Depending on what configuration MiniDSP you plan to employ the PA2 may save you some cash
Final Summary: On paper at the end of the day the PA2 is a good contender to go up against, and possibly beat the MiniDSP.
Addendum: DBX also offers a model that is a step up from the PA2, called the Venue 360. It adds a few additional bells and whistles. If your budget allows, make sure to check it out as well. At the time of this purchase (12/25/2020) the Venue 360 was hard to find used, and those that I did find were 1.5 times more expensive than the PA2. Additionally new was not an option at all, and for those who do not have the internal conflict I do about buying a clone, the Sinbosen option was not available either.
__
Research
There are quite a few videos out there that really dive in deep into the software, as well as numerous reviews. While many of them are focused on the pro audio demographic (which makes sense given this is a pro audio device) and discuss various professional speakers, venues, etc, reading them let me understand various applications of the product and provided insight into what problems I might encounter in the Home Theater realm. To get you started, I've listed just a few of them below.
Videos:
Reviews:
Disclaimer
- I am not a professional reviewer, nor do I claim to be. If any of my information is incorrect, let me know so I can correct it.
- I do not plan to spend the next weeks recording and providing tons of measurements, etc. Yes I know this is Audio Video Science, but to be blunt I don't:
Care to spend the time to do so. This is my hobby, not my job. I have a wife and 2 small children and I will always prioritize spending time with them playing, or watching movies, over measurements.
Feel like tearing apart and re-arranging my gear 12321 times. I am currently recovering from a serious non-COVID medical condition and am very weak, so something that used to take me 5 minutes may take me 30, and simply do not have the strength to do it.
I do plan to take some measurements as I incorporate the PA2 into my system as its somewhat required to do so. I also have some prior measurements of my system with the MiniDSP. When possible if I can provide graphs that are a accurate A/B comparison using that prior data I will do my best to do so. - I also am of the belief (for better or worse) that some things you feel/hear cannot be adequately measured. I will likely use words that will drive some of you bonkers, including: Expansive, Depth, Soundstage etc. While it may be possible to measure some of them by graphing things like (distortion, etc), refer to Item #2.
DBX PA2 Cons:
- The Inputs must be EQ'd together. You cannot apply a diff EQ to the right input than the left. - For me not a problem
- Delay is 7ms (which is the same as the standard MiniDSP, but other MiniDSP products have higher delay available) - Not a problem for me as I was already limited to 7ms but since I really have 2 pair of equidistant subs, wont know till the other pair is completed. And even if I do need more than 7ms, I may be able to compensate by playing with the "Distance" setting in my AVR.
- Each set of L/R outputs must be EQ'd together. This means while there are 6 outputs, you really only have 3 stereo pair. - Given my configuration, this should provide me enough options, and possible even allow for the addition of a set of MBM's.
- LCD screen is a bit bright and cannot be dimmed - easily fixed by purchasing an item like these LightDims Black Out Edition
- I read it outputs a fair amount of heat. I've yet to confirm this.
- Wont EQ below 20hz. You can use the same trick for the iNukes to set a highpass filter below 20hz for ported subs. - I'm using sealed subs so while it would be nice to be able to EQ below 20hz, I honestly will just use the iNuke trick to set a highpass at around 15hz which will both: protect my subs from overexcursion and allow me to push the system a bit more as a result
- 8 PEQ bands on Input and Output. The Mini has 10.
- Lack of support of the Home Theater enthusiast masses, which has resulted in various custom solutions based around the MiniDSP architecture.
- Multiple ways to program: LCD on the faceplate, Laptop/iOS/Android app, which is like having a built in WI-DG
- Quick Access buttons to program various pieces such as Xover, Delay, Limiter, etc
- Mute buttons for every input/output on the unit, and in the software
- Has its own AutoEQ with the addition of a RTA-M microphone
- Multiple Presets can be created, and recalled easily. This means I can have one preset for most viewing (aka when my wife who isn't a fan of large amounts of bass), and another for when I'm home alone and want to crank it to 11.
- Native XLR input and outputs. To get this with my Balanced unit, I had to spend a fair amount for a custom enclosure, which I love, but I'm still using phoenix connectors internally
- Toroidal Transformer rather than wallwart. wallwarts can introduce noise into a system
- Standard Size for rack mounting or placement in a cabinet
- LED's for signal strength for input and each channel
- Inputs can be configured for either +4dBu/-10dBv usage. From what I'm reading AVR users would want to use the -10dBv setting, while those with Processors would want to use the +4dBu setting. I have mine at the -10dBv setting with my Denon.
- Ground lift switch - useful to try and fix any ground loop hum
Cost differential:
DBX PA2
New a DBX PA2 will cost you around 440. Lightly used/refurbished units can be found on eBay for around 200-250 if you are patient. The DBX RTA-M mic new will cost you 100. As with the PA2, you can find open box/used mics for around 60 on eBay. For those that want a new unit at a lower price, there is a "clone" available from Sinbosen for around 200 USD last time I looked.
Authors note about clones: When possible, I prefer to buy EOM models (new or used). The bargain hunter/cheapskate in me appreciates the pricing of clones as it sometimes puts something within grasp that otherwise would not be. The idealist in me struggles with the fact that by purchasing them I am funding/encouraging those performing Intellectual Property Theft to continue to do so.
I went the used route and my PA2 cost me 208 after tax and the RTA-M cost me 60 for an all in cost of 268.
MiniDSP
A MiniDSP is going to cost you a minimum of 104 (2x4 RCA) to 209 (2x4 HD). The WI-DG is going to run you about 90, and a UMIK mic will cost anywhere from 90 (parts express) to 110 (Cross spectrum calibrated mic). My recommendation is always for the Cross Spectrum since its a more accurate and is calibrated higher and lower than the stock model.
So all in, the cheapest you can get away with for a MiniDSP system is around 304 dollars (104 2x4 + 90 WI-DG + 110 Cross Spectrum UMIK-1). Given that most people would recommend the 2x4 HD all day over either the 2x4 or 2x4 balanced, the more appropriate cost for a MiniDSP setup is 409 (209 2x4 HD + 90 WI-DG + 110 Cross Spectrum UMIK-1). I am sure given time and patience you could spend less by buying used as they come around, but it will take longer to source 3 pieces used.
__
Research
Videos:
- dbx DriveRack PA2 Custom Speaker and Amplifier Setup - dbx
- dbx DriveRack PA2 Loudspeaker Signal Processor Overview - agiprodj
- DriveRack PA2 Review! - code
Reviews:
- Dbx DriveRack PA2 - Sound on Sound
- Review: dbx DriveRack PA2 Loudspeaker Management System - American Songwriter
- dbx DriveRack PA2: The Future of Audiophile Systems - Audiophile Nirvana (skip the other linked articles. They don't really dig much more into the PA2 further)
