1 - 4 of 4 Posts
· Registered
I just hooked up a Motorola DCT6416 and it seems to be emitting a high pitched buzz/whine. It's not very loud, but it's still a noticeable annoyance. This happens when the box is both on and off.
Unfortunately the item is from eBay, so exchanging it for another box isn't really a viable option. I'm hoping that I can find the source of the noise and correct it instead. It doesn't seem to be the fan, so I may have to take the thing apart...
Has anyone else experienced this?
· Registered
Discussion Starter · #3 ·
Originally Posted by bicker1 /forum/post/0
I'm confused -- why would getting the item from eBay preempt returning it if it is noticeably defective as you've described?
You're right, I could return it if it is in fact defective. I've read that these things are loud, but this seems to be higher pitched than normal fan noise. It's subtle, but it's definitely there.
1 - 4 of 4 Posts
