Status
Not open for further replies.
1 - 4 of 4 Posts
it can be done, right ? or do I miss something (imposed by the dvdforum ? it could "shadow" the 5.1 dolby ?)
from a PCM dolby surround to a 192kbps dolby surround/stereo, there's an ENORMOUS loss of musicality, of details, of that "great audio feeling" that laserdiscs offered.
I just noticed for instance GARDENS OF STONE being announced by Columbia, in 2.0 only
I don't ask for remasters in discrete 5.1 necessarily ( I reall don't ) but a much higher data rate at least, and let the receiver-processor do his job of decoding it into prologic. DPLII with 192kps is a joke.
another useless ranting :D
PS: besides, mono tracks sound better in PCM too.
a quick list:
AUDIO (assuming digital only outputs, as most dvd players have poor analogic outputs )
untouched masters: LD !
dolby 5.1 - AC3 : less dialnorm issues on ld
DTS: LD ( full rate always ) but non issue to me. half rate is quite good enough (uncorrect dialnorm, cooked down discs, 192kbps are bigger issues !)
dolby surround: LD !!!!!!!
mono: LD !!!!!
distorsion: dvd ( because the masters seemed to have often been checked )
VIDEO ( assuming the discs are viewed in via the best possible paths and are well mastered)
details: dvd !!
depth: dvd !! (goes with S/N)
resolution: dvd ! ( especially anamorphic )
video S/N : dvd !!!
compression: ld !!! ( :D )
colors: dvd !
blacks: dvd !!
contrast: dvd !!
fluidity: now on par
continuity (sides): dvd :D
edge enhancement: ld !!!! :D
It can be done no problem. Most authoring houses don't unless you specifically tell them too. If the music is really that important however you might as well just go for a full PCM track.
Discussion Starter · #3 ·
a full PCM track would take too much space. from 192 to 448kbps, there is a big audible difference. music "that" important ? isn't "sound" "that" important ??
sometimes I wonder how many people watch their dvds with the sound turned off :D
the vast majority hasn't experience laserdisc, that's also true :D ( US household penetration: 2.5% )
Banned
There are some of us not equipped to decode 5.1 or DTS, I downmix the aformentioned numbers to PCM surround, which is decoded by my sennheiser unit.
I have told all why I must wear earphones in the oldies place I unfortunately live in. Take at high as you want but I have to set my DVD players to down mix, in order for Sennheiser to work to give me a Dolby Pro-Logic 5 sounds from headphones!
I have called the 1-800-recoton number to be snail mailed literature on a 5.1 Dolby Surround from 900 MHz. Wireless headphones price $279 as seen in the June issue of Sounds and Visions magazine. This set is about 50% of what the Sony wireless headphone outfit costs. I have personal experience of owning Recoton products.
Pictured in advertisement next to page 96
in Sounds & Visions if any of you 'I have to have my loud speakers' want to read about the new device seen, it won't spoil your hairdoo or perms guys. lol :)
1 - 4 of 4 Posts
Status
