1 - 7 of 7 Posts
We will start out with my hardware:
Onkyo 806 Receiver
GIGABYTE GA-X48-DQ6 motherboard
Nvidia 9800 gx2 video card (dvi x 2, hdmi outputs)
My motherboard has s/pdif out (2 pin connector) and my video card has s/pdif in (2 pin). My question is would I be able to get DTS-HD or DD+ to my receiver from my computer. I heard that bitstreaming is not possible yet from my computer without a crazy video card. Would there be some way to change the audio into something different...I read like 4 x 2 streams or something. Sorry I'm not good with all this audio lingo. I read there is a way to do it, the sound will get there in full bandwidth but the receiver wont light up with DD+ or true HD. I think it was using cyberlink powerdvd ultra or something.
What is the limiting factor which limits the bandwidth of these HD audio signals? Is it the s/pdif connector in general or is it the medium that is used to transport the signal to the receiver (optical and coax). What I plan on doing is connecting the s/pdif out on my motherboard to the s/pdif in on my video card and using hdmi to transport video and audio to the receiver. Right now im using optical but i will switch to hdmi in a few hours.
With this setup is there any way to get the HD audio to the receiver. I know the receiver probably wont have a chance to decode it but if the computer could decode it and send it to the receiver a different way where it is already processed similar to what the ps3 already has or whatever. Would I be able to do it cause hdmi has a lot more bandwidth than optical or coax. Am I out of luck with my setup or is there hope without buying that super expensive Asus card that everyone is talking about. I hope I didn't leave anything important out here with my setup. Thanks in advance.
Premium Member
S/PDIF supports only stereo LPCM, DD and DTS. It looks like S/PDIF has more bandwidth, but this is the fact. The best you can do with your current components is connect the internal S/PDIF connector of the mb to the S/PDIF connector of the video card with a proper cable, and use the onboard digital audio (Realtek Digital Audio) as the playback device. Then you will get stereo LPCM/DD/DTS over HDMI. You can use DTS Connect as default (so every sound including Dolby TrueHD and DTS-HD Master Aduio is first decoded to multichannel LPCM, then encoded into DTS and sent over HDMI), but this is not necessary because PowerDVD/TMT has a built-in DD/DTS encoder.
Of course you can use an optical or coaxial cable separately from video cable. The audio signals are exactly the same as above.
Discussion Starter · #3 ·
Are there sound cards that do multichannel pcm. And are those cheaper than a soundcard that can actaully do bitstreaming. Cause I guess Powerdvd can take the dts-hd or whatever and change it into multichannel pcm. Whats the best sound card that would work for me that has the best price.
Premium Member
Yep, PowerDVD/TMT decodes HD audio formats into multichannel LPCM and sends them to the audio device. But multichannel LPCM is supported by only HDMI. So you will need a sound card supporting HDMI or a graphics card with a built-in HDMI audio controller.
- ASUS Xonar HDAV1.3
- Auzentech X-Fi HomeTheater HD (available soon)
- Radeon HD 4xxx graphics card.
The first two HDMI sound cards support not only multichannel LPCM but Dolby TrueHD/DTS-HD Master Audio bitstreams (so the player does not decode them). Radeon HD 4xxx supports only multichannel LPCM.
Discussion Starter · #5 ·
does the Xonar HDAV1.3 do bitstreaming via hdmi so my receiver could decode the audio signals?...cause that would be ideal instead of multichannel pcm
You've omitted the S3 Chrome 530GT. Not sure why this forum is more interested in overengineered HDMI re-encoding devices than this thing.
Could you not use the analogue audio outputs from the PC to the External input on the 806?
I am not sure if you first have to remux to mkv with flac, or whether AnyDVD_HD enables analogue lossless output directly from the HD-DVD / BluRay.
1 - 7 of 7 Posts
