1 - 5 of 5 Posts
My 5040 doesn't even show the please wait screen
hard drive works in another 5040 great?
done the hard reset.
unplug leave overnight.
blue light does come on.
connect just the video.
Any suggestions would be great.
Its worked for a very long time now, time to buy another one?
Try opening the cover and removing and re-plugging the power wire between the supply and mainboard a few times. Also, are you viewing with the compostie or s-video? you have to use one or the other, not coax.
Same thing worked for me recently (Thanks for the tip, Mikey).
1 - 5 of 5 Posts
