^ Odds are you have the Sub's own internal Crossover enabled at 80Hz. (You'd also get this with a "THX" setting in the Sub.)
On the Sub itself, set the Sub to disable or bypass its internal Crossover. If there is no option for that, set its internal Crossover to the highest frequency available to get it out of the way as much as possible.
For some Subs, there is a separate input jack to use when you want to bypass the Sub's internal Crossover.
--Bob
--Bob
