I get a little hum in my subwoofer that seems to be caused by the cable TV. When I unplug the cable, the noise goes away. I added a ground from the TV cable to my surge suppressor and that helped a lot. I'll be getting an electrician to do a few small projects at my house. Would there be any benefit to running a dedicated circuit with a few outlets to (1) lighten the load in general and (2) reduce any noise since all the lights and other things would be on another circuit? He's licenced and bonded, but haven't asked about his audio back ground yet. Is there anything else I should do while I have his here? I'm sure it would be cheaper to do everything at once.
Panamax M5300EX running:
Onyko Pro PR-SC885
Panasonic 42" Plasma TV
Carver TFM-25 (225W x2) - for rear surrounds (Def Tech BP-2X)
One front speaker (Def Tech BP 7004)
Sony PS3
Sony CD player
Scientific Atlanta Explorer 8240HDC Cable TV box
Panamax Max1000? running:
Adcom GFA 5503 (200W x3) for center and front speakers
Center speaker (Def Tech CLR2300)
Sunfire True Subwoofer MKII
I split the amps between the surge protectors because I knocked out the cable TV box somehow when both were on the Panamax 5300EX. Too much current surge when both amps came on at once? The sub and left front speaker's cords won't reach, so I used the older MAX1000.
Onyko Pro PR-SC885
Sony PS3
Sony CD player
