1 - 2 of 2 Posts
What centers could I use with this setup and what would you recommend? The Def Tech website only recommends the CLR2002, but people on here seem to be using a number of different ones. I can't even find info on some of the numbers.
And is Hi-Fi Heaven a reputable store? I found the link to it on Audiogon and it has BPX surrounds for less than half of MSRP and what I can find anywhere else.
Discussion Starter · #2 ·
The 2002 has 5 1/4" drivers compared to the 6 1/2" in the BP10's, the 2300 and 2500 have smaller and equal size drivers with a subwoofer (doesn't seem worth it? ) Then the 3000 has the same size drivers as the towers, 6 1/2" and a bigger subwoofer. It's a lot more expensive though and pushes the 65 lb weight limit of my stand shelves at 62 lbs.
Should I try to match driver size, or would the 2002 be good? Is the subwoofer in it worth it? Assuming they're all timbre matched in the first place?
1 - 2 of 2 Posts
