1 - 3 of 3 Posts
Def Tech Mythos 10 users!!
I recently bought mythos10's as LCR to replace my promonitor 1000's and pro center 1000c. I can see the difference if I change only the Center with mythos 10. But if I either connect with promonitor or mythos 10's as L&R, I am unable to differentiate which one is good. If you have similar experience or any insight on this setup greatly appreciated. Between I use Denon X4400H with 9.1 setup. I use Bipolar 9040's as rear and height channels from speaker craft Aim one;s.
Thanks in Adv,
Shiv
That's because center channel is the most important part of the equation (sometimes 70% of content), stay timbre matched and go with the Def Tech's
1 - 3 of 3 Posts
