Not sure if it's me or if the 8020s are just too small to fill my 25x30 theater room
They replaced a set of aging Klipsh KG5.5s
I was swinging between the def techs and Polk Rita7''s
I've got them set up as full range and using a home built 12" 500w sub for bass
The bass from the def tech is most definitely clearer and defined than the Klipsch.
Any ideas out there?
