1 - 2 of 2 Posts
Discussion Starter #1
ok here's my equipment:
pioneer elite vsx-36tx
def tech bp6 mains
def tech clr2300 center
def tech bp1 surrounds
def tech powerfield 1500 sub (250watts)
my ?'s are:
my crossover network gives me 3 options (80hz,100hz,150hz) which should i use?
my other ? is, i'm upgrading my sub... i'm leaning toward the def tech supercube II... i really want kicka$$ punch... so, will one do or should i go for two? or possibly three supercube III's?
just weighing options for price & power...
help!!!!!!!!
I would say 80Hz as the crossover. I used to own the CLR2300 and it can handle 80Hz just fine.
What is your budget for a sub?
Do you have any size constaints or WAF?
Not trying to pull you away from Def Tech but depending on budget I think you may want to consider some others.
Just my 2 cents here...
1 - 2 of 2 Posts
