Status
Not open for further replies.
1 - 2 of 2 Posts
I have a Sony KV-32HS510 and it looks like it nees to be degaussed. Does anyone know if there is a secret menu inside the TV were i can make it degauss itself. Found the wands, but trying to save money before investing in them.
Jesse
You might try your question in the regular view TV forum - http://www.avsforum.com/avs-vb/forum...?s=&forumid=64
Often you can use the butt end of a Weller soldering gun to degauss. Its a cheap (and usually effective) alternative.
Did the TV get dropped or banged? If so, the color problem may be due to a damaged shadow mask, which basically means the picture tube would need to be replaced.
Good Luck!
Kieth
1 - 2 of 2 Posts
Status
