1 - 2 of 2 Posts
My 1610 wont stay on. I turn it on and it stays on few seconds they turns off. Red blinking light. I messed with all connections and still does this. I also unplugged all speakers and tried, still nothing.
So i unplugged everything and plugged into a different outlet and still did the same.
Any suggestions? Its about 3 years old
Premium Member
If it is shutting down with no connections (sources or speakers) and the power ring is flashing at a fast rate (ie. every 1/2 second), with clear and open ventilation, then the unit may be having amp failure problems. As a last resort, try resetting the microprocessor (p. 57 OM). If still no joy, then you may still be able to pursue warranty repair. If purchased from an authorized reseller, the unit would have a 2 year warranty, however, if purchased with a credit card, your card issuer may add an additional year making it 3 years (Amex will for sure as will some MC/Visa) so it would be covered for repair/replacement if still inside 3 years.
1 - 2 of 2 Posts
