I'm considering an upgrade, probably to the Denon 2802, and would like some questions answered.
- Can you rename the input sources? It doesn't seem so from the manual.
- I'm somewhat space challenged.. Does the stated depth of 416mm include protruding parts? (I think the 3802 is the same size.)
- What exactly is possible/impossible to do without using the OSD? For example can you adjust bass/treble or rear/center levels without the OSD?
- I currently have a Sony STR-DB830. How much improvement in sound quality can I expect (especially for music), and how would you characterize the Denon sound compared to the Sony?
- I'm also considering the more expensive Denon 3802 and Yamaha 1200. Opinions?
/Johannes
/Johannes
