I have just connected a new Denon 2900 DVD to my NAD T752 (via optical digital sound and component video). The front and centre speakers are driven through a NAD 906 bridged multi-channel power amp using the T752 pre-outs, the sub is connected using the T752 sub pre-out and the surrounds are driven through the T752. My speaker set up is: B&W 603 S3 fronts, B&W LCR600 S3 centre, Advent Legacy surrounds and an M&K V75 sub. All speakers are set to Large on the T752. (Also have a Strong SD digital TV box going to the T752 using component via Scart and Hantrex RGB to Component Box and then to a WideScreen LG 76 cm TV)
The video side of things is good - great picture quality.
There are, however, some funnies with the sound side of things from the Denon 2900.
1. DVD DD 5.1 is fine – all speakers driven including the sub
2. DVD DTS 5.1 does not drive the sub
3. CD – input to the T752 is shown as stereo but does not drive the sub – but when playing CDs on my Yamaha CDC565 CD player, with an analogue link to the T752, the sub is driven.
2. & 3. can only be rectified if all speakers are set to small on the T752.
I can’t understand why the T752 cuts out the sub with CD input from the Denon 2900 but does not with CD input from the Yamaha .
It also does not seem right that DVD DTS does not automatically pick up the sub with all speakers set to large on the T752 – it did with my previous “el cheapo†AWA DVD player.
Can anyone help ????? (Kris Deering ???????)
