I had the same problem when I used AVIA.My sub needed to be set to +6 and that was way too high.Never had that happen with my 2800,just with the 3801.
Anyway I just set it to about +2 or by ear and let it go.
Try the 3801 and then the AVIA and which ever is right to you.I know that's kind of vauge,but I don't understand why it did that.I've set up 3 3801's so far and found that 2 had the same problem.
I don't like my bass to be too over powering,just very effective.
The Denon should be handling the 80hz,but if you hear any "voices"from it,then set it down some.I've run powered subs before but can't remember how I set them.Don't think it matters,but play with it.
Denon AVR-3801
Klipschorns(77')Heresy(75')center,KSP-S6 sides,IW-150's rear.
2 12"DIY subs feed by 200 watt Yamaha amp,1 12" powered sub thru surrounds.
Sony DVP-C650 D dvd
Echostar 4700,JVC S7600 U
[This message has been edited by Stephen P (edited 12-24-2000).]
Denon AVR-3801
Sony DVP-C650 D dvd
