1 - 9 of 9 Posts
I have a Denon 3803 that I am using as a pre, combined with an Outlaw 7700 amplifier.
If I hook up a digital coaxial cable into one of the digital coaxial inputs on the back of the Denon, regardless if it is hooked up to a source (DVD player, Tivo) it causes the ground loop hum into the amp.
Before I take it in to the shop and get charged a ton to "troubleshoot", is this something that could be easily fixed, or could there be some kind of compatability issue with the RCA pre outputs and the digiatl coaxial inputs?
I prefer the use of coaxial cables to optical only because the cable seems to fit more secure into the plug.
Did you go through the "Hum FAQ" sticky in the Audio theory, Setup and Chat forum?
My guess is the all-to-common CATV-induced hum.
Read the FAQ and try the suggestions/advice listed there.
Discussion Starter · #3 ·
While I had not checked that sticky, I have done a lot of troubleshooting just like mentioned in that post.
I do have satellite from DirecTV. When everything is unplugged from the Denon, there is no hum. If I plug in a digital Coaxial into the Denon, the hum appears.
You just plug the cable into the AVR and not the source and the hum starts?
Strange, plug in just a basic RCA cable and see if it produces the same result.
This is a bit of an odd ground loop, I suppose the cable could be bad. 99% of the time hum is caused by the Sat or Cable no tbeing grounded properly.
Discussion Starter · #5 ·
JD,
Yes, everything is unplugged except the RCA cables from the Denon to the amp. There is almost no noise whatsoever coming from the speakers. There is a very very very faint buzz but only audible if you have your ear right at the horn tweeter (Klipsch RF7s).
Plug in a rca digital coaxial into one of the 2 inputs and BAM, BUZZZZZZZZZZZZZZZZ!. Unplug it it goes away. Plug in a RCA cable into one of the 5.1 anaologue inputs and same thing.
The TV, Satellite, sub, all is unplugged and disconnected from power.
I am running a Monster Power 2600 to provide "clean" power. I unplugged that and plugged the amp and Denon into a different outlet and no relief.
Originally Posted by cp1966 /forum/post/0
JD,
Have you tried different cables?
Digital Optical, for instance??
Discussion Starter · #9 ·
Just to give a long overdue update;
After talking with Outlaw, they believed it was in internal part with the amp. They took thew amp back and sent me a new one. I also bought the Outlaw 990 preamp to replace the Denon, and I bought balanced cables offered by Outlaw.
The result;
WOW!
No hum, and the 7700 really made my Klipsch RF7 and its little brother n sisters sing loud and proud!
The only bad thing is the 990 has no HDMI inputs.
1 - 9 of 9 Posts
