Status
Not open for further replies.
1 - 2 of 2 Posts
Does anyone know of a universal remote code for the 3803 that will work with the Samsung HDTV DirecTV receiver? I don't have the original remote so I cannot simply learn the codes?
Or can anyone recommend an inexpensive univeral remote that has a code for the Samsung? I saw over on remote central that there is a Philips model that works, but I am curious as to any others people have figured out since January of this year
thanks!!
I had the same sort of problem with my RCA receiver, but I still have the remote. Instead of going through the learning motions, I figured it was easier to start programming in DBS codes to the Denon remote. Starting at 3500 I tried every one and got lucky at 3537. It may take half an hour to sit there and push all the programming buttons and use the power button to test, but it pays off.
1 - 2 of 2 Posts
Status
