Denon 3910 4:3 picture streaching problem!
1069 Views 31 Replies 8 Participants Last post by  Dave Vaughn
I have just purchased Denon 3910 and was very impressed with the PQ. However I'm having hard time adjusting 4:3 picture using DVI connection. 16:9 picture shows fine but as soon as I insert full frame 4:3 dvd 3910 stretches it and it seems like none of 3910 aspect ration setup options will allow me to add black side bars to my 4:3 picture.
Anyone had this problem before??? Please help! :) I'm sure 3910 has a way to adjust 4:3 otherwise this is a shame...
Status
Not open for further replies.
1 - 20 of 32 Posts
squeeze mode on the 3910 setup. Not automatic.
So basically this will squeeze the 4:3 pic all the time so I won't have to worry about changing the ration when i'm watcihg 4:3 or 16:9?
Thanks I will try that and will post the reply later today.
It will not do it all the time you will have to turn it off and on.
So if squeeze mode is on then that will effect the 16:9 pic.? Is there so kind of shortcut of ir command that lets you change this setting quickly instead of going in the menu? I'm at work now and will check that in few hours, hopefully that will help. I love the player and the PQ but this seem to be a little problematic...
You have to go through the menu. Of course if you have a good programmable remote (like a Pronto) you can code up a macro (which emulates the key stokes).. or change the aspect ratio on your display if possible.
Tinker, thank you very much, i tried turning squeeze mode and it works fine!
But i noticed other minor issue, you know how some dvds (mostly music videos) that are in 4:3 format, have some tracks in 16:9 format, so before with my previous dvd, that was connected throught component i had my projector ration set on zoom it was perfectly playing 16:9 dvds and then if it was 4:3 dvd with 16:9 track it was working just like 16:9 because it was chopping off black bark on the top and the borrom. Is there any way to do so with 3910? For some reson when i use DVD input on my SONY VPL-HS20 projector it disables aspect ration settings so i can not do anything it it.
thanks!
The letter-boxed widescreen DVDs are tough ones to deal with. You will need a specialized zoom function in DVD player. Your projector will lock in full mode in 720p or 1080i mode as most other TVs.
mtrx,
With my Sammy DLP I can zoom in on "letterbox'd " widescreen DVD's and they look like they are 16:9 format with a very slight chop off all around, very minor almost = to standard TV overscan. But that just the Sammy doing its thing. I dont have a 3910 but I have a 2910. I never use the squeeze mode of the DVD player. I just use the wideTV (16:9), 4:3 and zoom modes of the Sammy to do the ratio thing since I can control it via the TV remote without having to go into the DVD player's menu. Sorry I dont think there is a method to have the 3910/2910 do auto ratio of all contents. My older Panni RP91 and F65 can do the auto sizing tho.
Tinker,
I suspect your Sammy DLP will not allow you to zoom or change aspect ratio if you feed it HD signals (720p or 1080i). For 480p, all TVs (except some old Philips TV) can do these tricks.
Greetings,
The reason that you can not adjust the aspect ratio control on your HS-20 is that you are feeding it a 720p signal. The Sony will not allow adjustment of the AR when fed a 720p or 1080i signal. You can adjust it via DVI when you feed it a 480p/576p signal though. I also have the Sony and I change the format to 480/576p when viewing 4:3 letterboxed DVD's. This allows me to set the AR to ZOOM mode on the Sony. There is really no discernible difference in the quality of the picture with 4:3 letterboxed DVD's viewed in either 720p/1080i/480p/576p IMO.
Originally posted by Foxbat121
Tinker,
With all sources I can select at least 16:9 (Wide TV) and 4:3 with my HLP6163. I can play HD on 4:3 but the pic is compressed at the sides and everybody looks like their on a diet...:D But no zoom with 720p/1080i/HD. The TV doesnt only lock to 16:9 with those sources, I can still select 4:3.
correction: no zoom with 480p/720p/1080i, zoom on the Sammy will only work with 480i.
Ralph, i will try it at 480i to see if SONY lets me change the ratio. However after playing with it last night i found another solution. If I connect 3910 to my sony projector with component i can change the ration to zoom in my projector which does what Tinker mentioned. PQ is almost the same, at least i can't see the difference with my eyes. Component i think is getting 720i picture even if you have it set to 1080i.
Nope, if you use component, you're only getting 480p or 480i. These players will not upscale over component out.
Foxbat121, what is the Progressive pic? Isn't it 720? not 480? So if you can get progressive pq out of component then it should be 720, right?
Progressive can be either 480p or 720p or anything ends with p. You will not get 720p out from component from this player, period.
Greetings,
MTRX, Fox is right. Nothing more than 480p/480i via component outs.
mtrx,
Due to industry pressure, DVD manufacturers avoid sending anything higher than 480p out of the analog video outputs (such as Component) because those connections offer no copy protection. 720p and 1080i resolutions will only issue from the digital video outputs (HDMI or DVI) on DVD players. Keep in mind that the data on the DVD itself is only 480i, so anything higher sent out by the DVD player is created algorithmically from that 480i data.
This is distinct from cable or satellite HDTV boxes which usually WILL allow the higher resolutions to go out their Component outputs. The industry is not thrilled with that, but there are so many HDTV sets with only Component inputs out there that the industry has to live with it since otherwise Component TV owners wouldn't see any gain from paying for HDTV.
--Bob
See less See more
By the way, there *ARE* DVD players out there which will automatically switch what they send out to a wide screen TV according to whether the DVD is issuing data in conventional 4:3 or wide screen 16:9 format. They do this by putting "pillar boxes" on either side of the 4:3 image to flesh it out to wide screen.
This is most definitely "not a good thing" if the player is sending out a 480i or 480p signal to the wide screen TV because the pillar boxes take up too much of the available resolution leaving less for the 4:3 image in the middle of the screen. So typically you would only WANT this if you are using a digital connection from your DVD player and the DVD player is generating a 720P or 1080i signal upscaled from the 480i data which is on the DVD itself. The extra resolution in the generated, upscaled signal allows the DVD player to insert the pillar boxes without degrading the data coming off the DVD which sits snugly in between the boxes with plenty of leftover resolution.
For example, the Pioneer Elite 59avi does this out of the HDMI output in it's "HDMI 16:9 Compressed" mode. Using this setup, the 59avi automatically switches what it sends to a wide screen TV between normal 16:9 and pillar boxed 4:3 according to what's coming off the DVD, even changing scene by scene if necessary. But you'll be much happier using this if you only use it when the HDMI output is set to 720p or 1080i resolution. At 480i or 480p resolution the pillar boxed 4:3 images will be degraded due to the resolution consumed by the pillar boxes themselves.
--Bob
See less See more
Bob, thanks for your reply, it was very helpful and educating :) Regarding players that automatically switch resolution there is SONY ES 999 model that does that for you, can tell it what to do with 4:30 add bars or stretch it. That player i guess is discontinued. Looks like SONY is going to come out with a replacement for this one that will have DVI and possible HDMI outputs. I will think DENON has the best PQ. I was really amazed with 3910 pic. The only confusion for me now is that I can't watch all the movies on DVI since Component sometimes provides a better pic.
So then that doesn't make sense. Should you have a better PQ if you are upconverting from 480i to 720p or 1080i?
Btw, I have several dvds that were captured in HD and it's says on the cover that this DVD is in HD. Does that mean that video on those dvds in 1080i? Didn't you mention that all dvds are in 480i?
thanks!
See less See more
1 - 20 of 32 Posts
Status
